TRIM
Bulk Data Entry Specifies the constraints for aeroelastic trim variables.
| TRIM | SID | MACH | Q | LABEL1 | UX1 | LABEL2 | UX2 | AEQR | |
| LABEL3 | UX3 | etc. |
| TRIM | 23 | 0.8 | 110.0 | URDD3 | 1.0 | ANGLEA | 6.0 | 0.0 | |
| URDD5 | 0.3 |
| SID | Trim set identification number. 1
                                    2 (Integer > 0)  |
| MACH | Mach number. (0.0 ≤ Real < 1.0)  |
| Q | Dynamic pressure. (Real > 0.0)  |
| LABELi | The label identifying aerodynamic trim variables defined on
                                    an AESTAT or AESURF
                                        entry. (Character)  |
| UXi | The magnitude of the aerodynamic extra point degree of
                                        freedom. (Real)  |
| AEQR | Flag to request a rigid trim analysis.
 (0.0 ≤ Real ≤ 1.0)  |
- The TRIM entry should be selected with the Case Control command TRIM.
 - The SID should be unique among all the TRIM entries.
 - The selected TRIM entry specifies the constrained values of the listed extra point degrees-of-freedom (“trim variables”) for a particular loading condition. These variables are listed on AESTAT and/or AESURF entries.
 - The unit of the angle of attack (ANGLEA) and the angle of sideslip (SIDES) is radians.
