TICA
Bulk Data Entry Defines the initial velocity on a set of grids along and about an axis.
Attention: Valid for Implicit
                    and Explicit Analysis
| TICA | SID | GSID | VT | VR | |||||
| GA/XA | YA | ZA | GB/XB | YB | ZB |
| TICA | 100 | 10 | 3.0 | 4.0 | |||||
| 123 | 0.0 | 0.0 | 1.0 |
| SID | Unique identification
                                    number. (Integer > 0)  |
| GSID | Grid point set
                                identification number. Default = all grids in the model (blank or Integer > 0)  |
| VT | Initial velocity along the
                                    axis. (Real)  |
| VR | Initial velocity about the
                                    axis. (Real)  |
| GA, XA, YA, ZA | Axis origin. These fields
                                define the origin of the axis. The point may be defined by entering
                                a grid ID in the GA field or by entering X, Y,
                                and Z coordinates in the XA,
                                    YA, and ZA fields; these
                                coordinates will be in the basic coordinate system. Default is the origin of the basic system (Real in all three fields or Integer in first field)  |
| GB/XB, YB, ZB | Direction of vector for
                                axis definition. These fields define a point. The vector goes from
                                the anchor point to this point. The point may be defined by entering
                                a grid ID in the GB field or by entering X, Y,
                                and Z coordinates in the XB,
                                    YB, and ZB fields; these
                                coordinates will be in the basic coordinate system. No default (Real in all three fields or Integer in first field)  |
- The TICA entry can be referenced in the subcase using the IC Subcase Information Entry.
 - TICA is primarily used for simulating the uniform rotation of a structure about an axis by defining VR and an axis. A helical (or spiral) shaped motion can also be achieved by defining VR, VT and an axis.
 - Support information for this entry is:
- Direct Transient Analysis (DTRAN)
 - Explicit Dynamic Analysis (NLEXPL)
 - This card is represented as a load collector in HyperMesh.
