SWLDPRM, CHKRUN
Bulk Data Entry Stop or allow the run after the connectivities of all the connector elements have been generated. This parameter must be global, meaning it should be placed before the presence of the first connector keyword.
| Parameter | Values | Description |
| CHKRUN | <NO, 0,
                                        YES, or 1>  Default = NO  |
