SUPORT
Bulk Data Entry Defines determinate reaction degrees-of-freedom in a free body.
| SUPORT | ID1 | C | ID2 | C | ID3 | C | ID4 | C |
| SUPORT | 16 | 215 |
| ID# | Grid point identification number. No default (Integer > 0)  |
| C# | Component numbers. No default (Any unique combination, with no embedded blanks, of the integers 1 through 6 for grid points; or 0 for scalar points)  |
- The SUPORT entry specifies reference degrees-of-freedom for rigid body motion. It is not intended to be used in place of a constraint (SPCi entry or PS on the GRID entry, for example).
 - SUPORT and/or SUPORT1 entries are required to activate inertia relief unless PARAM, INREL is specified, then SUPORT and/or SUPORT1 entries are not required.
 - Be careful not to spell SUPORT with two Ps.
 - Degrees-of-freedom specified on this entry cannot be defined as dependent degrees-of-freedom in rigid body element or constrained in SPCi entry or PS on the GRID entry.
 - An alternative to SUPORT is the SUPORT1 entry, which is requested by the SUPORT1 I/O Options and Subcase Information command.
 - This card is represented as a constraint load in HyperMesh.
