SPCP
Bulk Data Entry Defines the flow pressure boundary conditions for Darcy Flow Analysis.
| SPCP | SID | G | D | G | D | G | D |
| SPCP | 2 | 32 | 0.0 | 33 | 0.0 | 34 | 0.0 |
| SID | Flow pressure boundary condition set identification number.
                                         (Integer > 0)  |
| G | Grid identification number. (Integer > 0)  |
| D | Enforced flow pressure value for grid designated by
                                        G. No default (Real)  |
- The SPCP Bulk Data Entry should be referenced by a SPCP Subcase Entry to define Flow Pressure boundary conditions and activate Darcy Flow Analysis. An SPCP Bulk/Subcase Entry pair is mandatory to activate flow analysis in steady-state heat transfer analysis. The INLTVEL Bulk/Subcase pair is optional.
 - For inlet flow conditions, there
                        are two options:
- Use SPCP Bulk/Subcase data to define both inlet and outlet flow pressures, leading to a definition of flow pressure differential.
 - Use SPCP Bulk/Subcase data to define outlet pressure and use the INLTVEL Bulk/Subcase pair to define the inlet velocity.
 - Continuation lines are not supported for SPCP Bulk Data Entry.
