SPCOFF
Bulk Data Entry Defines degrees-of-freedom to be excluded from AUTOSPC.
| SPCOFF | G1 | C | G2 | C | G3 | C | G4 | C |
| SPCOFF | 13 | 234 | 14 | 5 |
Definition
| Gi | Grid or scalar point identification number.  (Integer > 0)  |
| C | Component numbers.  (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points).  |
- Degrees-of-freedom on this entry will be excluded from AUTOSPC.
 - If both SPC and SPCOFF are defined for the same degree-of-freedom, then SPC takes priority
