SLOAD
Bulk Data Entry Defines concentrated static loads on scalar, grid or fluid points.
| SLOAD | SID | S1 | F1 | S2 | F2 | S3 | F3 |
| SLOAD | 21 | 3 | 4.5 | 4 | 29.0 |
| SID | Load set identification
                                    number. No default (Integer > 0)  |
| S# | A scalar, grid or fluid
                                point identification number. No default (Integer > 0)  |
| F# | Load magnitude. No default (Real)  |
- SLOAD may be referenced as the EXCITEID on an ACSRCE Bulk Data Entry.
 - Up to three loads may be defined on a single entry.
