SEQSET1
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis (Alternate Format).
| SEQSET1 | SEID | C | G1 | G2 | G3 | G4 | G5 | G6 | |
| G7 | G8 | etc |
Alternate Format
| SEQSET1 | SEID | C | G1 | THRU | G2 |
| SEQSET1 | 12 | 123456 | 2 | 45 | 923 | 1344 | 3 | 922 | |
| 23 | 26 |
| SEID | Superelement
                                identification number. No default (Integer ≥ 0)  |
| C | Component
                                    numbers. Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.  |
| Gi | Grid or Scalar Point
                                identification numbers (should be an external point). Default = Blank (Integer > 0, or THRU)  |
- Degrees-of-freedom on SEQSET entry should not be used on any other Superelement.
 - If the THRU option is used, then G1 should be less than G2.
