SDAMPING
Subcase Information Entry Used to apply modal damping as a function of natural frequency in modal solutions.
SDAMPING(type) = option
| Argument | Options | Description |
| type | <STRUCTURE, FLUID> | The referenced Bulk Data
                                Entry is applied to:
| option | <SID> No default  |
- SDAMPING can only be used in Modal Transient, Modal Frequency Response Analysis, and Modal Complex Eigenvalue Analysis; and must reference a TABDMP1 or TABDMP2 Bulk Data Entry.
 - Only one SDAMPING entry of each type can be defined for each subcase.
 - If present above the first subcase, it is applied to each modal frequency or modal transient subcase without an SDAMPING entry.
 - To achieve identical displacements in
                    Modal frequency response or Modal transient analyses when the
                        SDAMPING is used instead of PARAM, G,
                    the steps described here can be followed:
- The TYPE field in the TABDMP1 or TABDMP2 Bulk Data Entry should be set to CRIT.
 - Set the damping value (field ) in the TABDMP1 or TABDMP2 Bulk Data Entry equal to half of the value of PARAM,G (that is set the constant value to ).
 - Set PARAM, KDAMP,-1
