_s#_v.trn file
The _s#_v.trn file is an OptiStruct ASCII format results file.
File Creation
This file is only created for transient response subcases. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
| Result | Description |
| Velocity | Velocity results from
                                frequency response analyses.  Output is controlled by the I/O Option VELOCITY.  |
File Format
| Time"X Trans"Y Trans"Z Trans |
- The # in the file name is the user-defined subcase ID from which these results are obtained.
 - The _tran.mvw HyperView script file automatically creates plots for the results contained in this file.
