RSPEC
Bulk Data Entry Specifies directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for Response Spectrum Analysis.
| RSPEC | RID | DCOMB | MCOMB | CLOSE | |||||
| DTISPEC1 | SCALE1 | X11 | X12 | X13 | |||||
| DTISPEC2 | SCALE2 | X21 | X22 | X23 | |||||
| DTISPEC3 | SCALE3 | X31 | X32 | X33 |
Example 1
| RSPEC | 35 | ALG | SRSS | 1.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. |
Example 2
| RSPEC | 35 | SRSS | CQC | 0.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. | |||||
| 4 | 2.0 | -2 | -0.0 | -1. | |||||
| 2 | 17. | 0.5 | -2.5 | -1. |
| RID | RSPEC
                                identification number. Must be unique. No default (Integer > 0)  |
| DCOMB | Directional combination
                                    method.
| MCOMB | Modal combination
                                    method.
| CLOSE | Modal frequency closeness
                                parameter. 2 Default = 1.0 (Real ≥ 1.0)  |
| DTISPECi | Response spectrum
                                reference. Identification number of the DTI,SPECSEL entry. No default (Integer > 0)  |
| SCALEi | Scale factor for
                                    excitation. No default (Real <> 0.0)  |
| Xij | Components of a vector representing ground excitation i, j = 1..3 |
- DTISPEC2/SCALE2/X21/X22/X23 and DTISPEC3/SCALE3/X31/X32/X33 are optional ground excitations for multi-directional excitation. The directions of excitation have to be orthogonal to each other and will be reported as error otherwise.
 - When MCOMB =
                        SRSS or NRL, natural frequencies that are
                    close will be summed by the ABS method. The close frequencies
                    are determined using the inequality.
Where, and are successive natural frequencies.
Then, they are combined with other modal contributions in accordance with the specified MCOMB option. Since natural frequencies are in ascending order, CLOSE values should be greater than or equal to 1.0.
 - Response spectra values are defined as a table of frequencies in the X axis and the response spectra in the Y axis in a TABLED1 entry referenced by the DTI,SPECSEL entry. For any modes extracted during the response spectrum analysis that lie within or outside the range of the frequencies defined by the TABLED1 entry, linear interpolation or extrapolation is carried out to determine the corresponding spectral values associated with such modes.
 - Refer to Response Spectrum Analysis in the User Guide for more details.
