RESULTS
I/O Options EntryThe RESULTS command can be used in the I/O Options section to determine the frequency of output of analysis results for all subcases or for individual subcases, respectively.
RESULTS = frequency
| Argument | Options | Description |
| frequency | <FIRST, LAST,
                                    FL, ALL, NONE,
                                    N> Default = FL  |
- The information on this card pertains to all analysis output formats that are not specifically described by an OUTPUT command.
 - It is recommended to use the OUTPUT command as it allows different frequencies of output to be defined for different formats.
