RELOC
Bulk Data Entry Geometrically maps parts (for example, elements and grids) from one location to another. This entry allows you to define mapping as MOVE (translation), ROTATE, MIRROR, or MATCH (as an arbitrary transformation which matches grids from one group to similar grids in another group).
Each transformation can be defined by a combination of GRID points and numeric values (real numbers) representing distances and angles. The grid ID fields can be input as either numeric (positive integer) or fully qualified references to grid points in the model. Numeric references (without part name) specify grid points in the global part.
Translation (TYPE = MOVE) Format 1
| RELOC | ID | TYPE | GID1 | GID2 |
Format 2
| RELOC | ID | TYPE | dx | dy | dz |
Rotation (TYPE = ROTATE) Format 1
| RELOC | ID | TYPE | GID1 | ang_x | ang_y | ang_z | GID2 |
Format 2 (axis + angle)
| RELOC | ID | TYPE | GID1 | GID2 | angle |
Format 3 (axis + angle defined by grids)
| RELOC | ID | TYPE | GID1 | GID2 | GID3 | GID4 |
Format 4 (2D, grid + angle defined by grids)
Matching (TYPE = MATCH) Format 1
| RELOC | ID | TYPE | GIDA1 | GIDA2 | GIDA3 | GIDB1 | GIDB2 | GIDB3 |
Format 2 (2D)
| RELOC | ID | TYPE | GIDA1 | GIDA2 | GIDB1 | GIDB2 |
Mirroring (TYPE = MIRROR) Format 1
Format 2 (match + mirror)
Format 3 (2D mirroring)
Format 4 (2D, matching + mirroring)
| RELOC | 1 | MATCH | 1001 | 1012 | 3992 | 123 | 564 | 665 |
| ID | Set identification
                                    number. (Integer > 0)  |
| TYPE | This field specifies the
                                type of mapping between grid points in a model. The format of the
                                    RELOC card is different for different values
                                of the TYPE field. 2
| Translation (Format 1) | ||
| GID1 | Grid point identification
                                number for translation to the reference point location. Grid point
                                    GID1 is moved from its original location to
                                the GID2 location. (Integer > 0 or <PartName.number>) 4  |
| GID2 | Reference grid point
                                identification number for translation. GID2 is
                                used as a reference point to move another grid point
                                    (GID1) from its original location to the
| Translation (Format 2) | ||
| dx, dy, dz | Defines the distance that
                                the referenced part (INSTNCE entry) should be translated in the basic coordinate system. Each
                                entry specifies the corresponding distance moved in the X, Y, and Z
                                axes, respectively. 2 No default (Real)  |
| Rotation (Format 1) | ||
| GID1 | Specifies the
                                identification number of a grid point that will be used as a center
                                of rotation based on the angles specified in the following
                                    fields. (Integer > 0 or <PartName.number>) 4  |
| ang_x, ang_y, ang_z | Defines the angle (in
                                degrees) of rotation about the X, Y, and Z axes, respectively with
                                the grid point (GID1) as the center of rotation.
                                In a 2D model, only ang_z is specified. 2 No default (Real)  |
| GID2 | Specifies the
                                    follows: If GID2 is specified: The part is moved from GID1 to GID2, after a rotation about GID1. If GID2 is not specified: The part is not moved. Only a rotation about GID1 is done. (Integer > 0 or <PartName.number>) |
| Rotation (Format 2) | ||
| GID1,GID2 | Specifies the
                                identification number of grid points that will be used as axis of
                                    rotation. (Integer > 0 or <PartName.number>) 4  |
| angle | Defines the angle (in
                                degrees) of rotation about the axis defined by
                                    GID1 and GID2. (Real or blank)  |
| Rotation (Format 3) | ||
| GID3 | Specifies the
                                identification number of the grid point to be rotated. (Integer > 0 or <PartName.number>)  |
| GID4 | Specifies the
                                identification number of the grid point which, together with
                                    GID1 and GID2, defines a
                                plane to which GID3 is to be rotated. (Integer > 0 or <PartName.number>)  |
| Rotation (Format 4) | ||
                                identification number of the grid point that will be used as center
                                of rotation. (Integer > 0 or <PartName.number>) 4  |
                                    GID1, defines a line to which
| Matching (Format 1) | ||
| GIDA1, GIDA2, GIDA3 | Specifies the
                                identification numbers of grid points (initial location) that will
                                be moved to match with the corresponding grid points
                                    GIDB1,2,3 (final location, defined in the
                                following fields). Any rotation, translation or mirroring required
                                to complete this matching process is accomplished internally by
                                    OptiStruct. These three grid points
                                cannot be collinear. (Integer > 0 or <PartName.number>) 4  |
| GIDB1, GIDB2, GIDB3 | Specifies the
                                identification numbers of grid points which will be matched with the
                                corresponding grid points defined in the
                                    GIDA1,2,3 fields. Any rotation, translation
                                or mirroring required to complete this matching process is
                                accomplished internally by OptiStruct.
                                These three grid points cannot be collinear. (Integer > 0 or <PartName.number>) 4  |
| Matching (Format 2) | ||
| GIDA1, GIDA2 | Specifies the
                                    GIDB1,2 (final location, defined in the
                                    OptiStruct. These two grid points
                                cannot be coincident. (Integer > 0 or <PartName.number>)  |
| GIDB1, GIDB2 | Specifies the
                                corresponding grid points defined in the GIDA1,2
                                fields. Any rotation, translation or mirroring required to complete
                                this matching process is accomplished internally by OptiStruct. These two grid points cannot be
| Mirroring (Format 1) | ||
                                identification numbers of grid points about which the entire part
                                (defined via INSTNCE) will be laterally mirrored
                                (flipped) by 180 degrees. The grid points
                                    GIDA1,2,3 define an absolute plane of
                                symmetry flip. Any rotation or translation required to complete this
                                mirroring process is accomplished internally by OptiStruct. The three grid points specified
                                for mirroring cannot be collinear. In a 2D model, only
                                    GIDA1 and GIDA2 should be
                                    specified. (Integer > 0 or <PartName.number>) 4  |
| Mirroring (Format 2) | ||
                                cannot be collinear. (Integer < 0 or <PartName.number>)  |
                                    GIDA1,2,3 fields. After matching, the entire
                                part (defined via INSTNCE) will be laterally
                                mirrored (flipped) by 180 degrees. The grid points
                                    GIDB1,2,3 define an absolute plane of
                                symmetry flip. Any rotation, translation or mirroring required to
                                cannot be collinear. (Integer > 0 or <PartName.number>)  |
| Mirroring (Format 3) | ||
                                symmetry for mirroring. (Integer > 0 or <PartName.number>) 4  |
| Mirroring (Format 4) | ||
                                fields. After matching, the entire part (defined via INSTNCE) will be laterally
                                    GIDB1,2 define an absolute axis of symmetry
                                flip. Any rotation, translation or mirroring required to complete
- A RELOC entry can be referenced by a INSTNCE entry to define the location of a part in the full model. Additionally, the PERBC entry references the RELOC entry to define geometric relationship between two sets of boundary grid points.
 - The following illustrations depict part
                    relocation examples for each of the four TYPE field options.
                    All grid point ID's used on the RELOC entry can belong to any
                    part in the model. Only their initial locations are relevant. All
                        RELOC entries are evaluated before any parts are moved.
                    This may not always produce the expected result in some cases as the sequence of
                    moves affects the final part locations. For example, if
                    RELOC, MATCH is defined using three grid
                    points on part A and three grid points in part B, this may not result in a final
                    structure with the two parts being connected, if part B is moved again after
                    this matching process. To avoid such cases, it is strongly recommended to assign
                    the grid points that define the initial location to a part that has to be moved
                    and the grid points that define the final location, to a part that will not be
                    moved (for example, the global structure).
Figure 1. Translation - Format 1
Figure 2. Format 1 (Special case, assumes that Part B does not relocate)
Figure 3. Translation - Format 2
Where, is the distance moved by the part referenced on the INSTNCE entry, and dx, dy and dz are the distances moved by the part along the X, Y and Z axes.Figure 4. Rotation - Format 1
Figure 5. Matching - Format 1
Figure 6. Format 1 (Special case - Part B does not relocate)
Figure 7. Mirroring - Format 1
 - In a 2D model, only two
                    TYPE options are allowed: ROTATE and
                    MIRROR. All grid points in the model should have the same Z
                coordinate. Rotation and mirroring are defined in the X-Y plane.
Table 1. Rotation in a 2D Model Defined in the X-Y Plane (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) RELOC ID ROTATE GID1 ang_z Table 2. Mirroring in a 2D Model Defined in the X-Y Plane (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) RELOC ID MIRROR GIDA1 GIDA2  - In special cases where a model is defined
                in the X-Y plane (or a plane parallel to the X-Y plane), all
                    RELOC type options (MOVE,
                    MATCH, ROTATE and MIRROR) are
                supported to relocate the part in the same plane in the same way as a 2 dimensional
                transformation. In such cases, simplified card formats are implemented to provide
                easier specifications of relocation.Note: All grid points in the model should have the same Z coordinate. Rotation and mirroring are defined in the X-Y plane.
 - Supported local entries in specific parts can be referenced by the use of "fully-qualified references" on RELOC entries in the model. A fully-qualified reference (PartName.number) is similar to the format of a numeric reference. PartName is the name of the part that contains the referenced local entry (part names are defined on the BEGIN Bulk Data Entry in the model). number is the identification number of a referenced local entry in the part PartName. See Parts and Instances in the User Guide for detailed information on the use of fully-qualified references.
 - Relocation is computed internally using
                initial locations of all GRIDs specified on the corresponding
                    RELOC entry. It is not affected by any movement of parts due
                to the INSTNCE entry. For example, the entry
RELOC, 5, aaa.1, bbb.2does not indicate that parts aaa andbbbwill be connected together after all the INSTNCE cards are processed. - For RELOC entries using GRID match (MATCH formats 1,2 and MIRROR formats 2,4), the starting configuration should match the ending configuration. That is, the distances between matched GRID's should be the same prior to and after relocation (for example, GIDA1, GIDA2 to GIDB1, GIDB2).
