RCROSS
Bulk Data Entry Defines a pair of response quantities for computing the cross-power spectral density functions in random response analysis.
| RCROSS | SID | RTYPE1 | ID1 | COMP1 | RTYPE2 | ID2 | COMP2 |
| RCROSS | 20 | DISP | 50 | 2 | STRESS | 150 | 8 | 4 |
| SID | RCROSS
                                set identification number. No default (Integer > 0)  |
| RTYPE# | Response quantity type. At
                                least one field must be selected. If either
                                    RTYPE1 or RTYPE2 is blank,
                                then the blank field takes the default from the defined field.
| ID# | Element, grid, or scalar
                                point identification number. No default (Integer > 0)  |
| COMP# | Component code (item)
                                identification number. 2 No default (Integer > 0)  |
- This entry is required for computing the cross-power spectral density function. SID must be selected with the I/O Option RCROSS. Fields RTYPE1, ID1, and COMP1 represent the first response quantity and fields RTYPE2, ID2, and COMP2 represent the second response quantity.
 - For elements, COMP#
                represents a component of the element stress or strain as described below.
Element Stress/Strain Item Number Code All Solid Elements Normal X 6 or 12 Normal Y 7 or 13 Normal Z 8 or 14 Shear XY 9 or 15 Shear YZ 10 or 16 Shear XZ 11 or 17 All Shell Elements Normal X at Z1 3 or 4 Normal X at Z2 10 or 11 Normal Y at Z1 5 or 6 Normal Y at Z2 12 or 13 Shear XY at Z1 7 or 8 Shear XY at Z2 14 or 15  - For grid points,
                    COMP# represents a component of the displacement, velocity,
                acceleration or spcforce as described below.
- Response
 - Number Code
 - Translation X
 - 1 or 7
 - Translation Y
 - 2 or 8
 - Translation Z
 - 3 or 9
 - Rotation X
 - 4 or 10
 - Rotation Y
 - 5 or 11
 - Rotation Z
 - 6 or 12
 - For scalar points, COMP# should always be 1.
