Bulk Data Entry Defines the radiation material properties of a surface element for heat transfer
        analysis.
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | RADM |
                                RMID |
                                ABSORP |
                                EMIS1 |
                                | (1) |
                                (2) |
                                (3) |
                                (4) |
                                (5) |
                                (6) |
                                (7) |
                                (8) |
                                (9) |
                                (10) |
                                | RADM |
                                24 |
                                0.2 |
                                1.0 |
                                | Field |
                                Contents |
                                SI Unit Example |
                                | RMID |
                                Radiation material
                                    property entry identification number. No default (Integer >
                                        0)  |
                                | ABSORP |
                                Surface
                                        absortivity. No default (0.0 ≤ Real ≤ 1.0)  |
                                | EMIS1 |
                                Surface emissivity.
                    - The RADM entry
                        can be referenced by a CHBDYE Bulk Data Entry.
                    - The Radiation Heat Flux is
                        calculated as follows, between the surface element and the black-body space
                            node.
Where,
                                    - Radiation heat flux.
                                    - Stefan-Boltzmann constant defined via PARAM,
                                            SIGMA.
                                    - Radiation view factor between the element face and the
                                        ambient space node.
                                    - Surface emissivity of the surface element, defined by
                                            EMIS1 on the RADM
                                        entry.
                                    - Surface absorptivity of the surface element, defined by
                                            ABSORP field on the
                                            RADM entry.
                                    - Surface temperature.
                                    - Absolute temperature scale defined via PARAM,
                                            TABS.
                                    - Ambient temperature.
                    - For a Heat Transfer Analysis via
                        Radiation, PARAM,TABS can be used to define the absolute
                        temperature scale, and PARAM,SIGMA is used to specify the
                        Stefan-Boltzmann constant. Additionally, a RADBC entry
                        can be used to define radiation boundary conditions.
