PTADJS1
Bulk Data Entry Defines adjustment (additional shortening) on a set of pretension sections.
| PTADJS1 | PSID | ADJ | SID1 | SID2 | SID3 | SID4 | SID5 | SID6 | |
| SID7 | SID8 | SID9 | etc. |
| PTADJS1 | 3 | 0.05 | 1 | 3 | 4 |
| PSID | Pretensioning load set
                                identification number. (Integer > 0)  |
| ADJ | Adjustment applied on this
                                section (positive value means shortening). 2 (Real)  |
| SIDi | Pretension section
- PTADJS1 can be referred by PTADD or by the PRETENSION command in the subcase directly.
 - Pretensioning adjustment shortens the pretensioned bolt by "removing" the set amount of material. This represents the effect of turning the nut by a set distance (number of turns).
 - Pretensioning adjustment is an additional shortening applied to a pretension section. This means that, when adjustment is applied to a section that has already been pretensioned, the final effect will be a sum of the status reached in the preceding pretensioning subcase plus the amount of ADJ.
