PMASS
Bulk Data Entry Defines the mass value of a scalar mass element (CMASS1 or CMASS3 entry).
| PMASS | PID1 | M1 | PID2 | M2 | PID3 | M3 | PID4 | M4 |
| PMASS | 7 | 4.29 | 6 | 13.2 |
| PIDi | Property identification.
 No default (Integer > 0 or <String>)  |
| Mi | Value of scalar
                  mass. (Real)  |
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - Mass values are defined directly on the CMASS2 entry, and therefore do not require a PMASS entry.
 - Up to four mass values may be defined by this entry.
 - This card is represented as a property in HyperMesh.
