PLOTEL
Bulk Data Entry Defines a one-dimensional dummy element for use in plotting.
| PLOTEL | EID | G1 | G2 |
| PLOTEL | 29 | 35 | 16 |
| EID | Unique element identification number. Unique with
                                                  respect to all other element identification
                                                  numbers. No default (Integer > 0)  |
| G1, G2 | Grid
                                                  point identification numbers of connection
                                                  points. No default (Integer > 0; G1 ≠ G2)  |
- This element is not used in the model during any of the solution phases of a problem. It is used to simplify the plotting of structures with large numbers of collinear grid points, where the plotting of each grid point along with the elements connecting them would result in a confusing plot.
 - Only one PLOTEL element may be defined on a single entry.
 - This card is represented as a plot element in HyperMesh.
