PLOADXG
Bulk Data Entry Defines a surface traction on the general axisymmetric elements CQAXIG and CTAXIG.
| PLOADXG | SID | EID | GA | GB | CID | N1 | N2 | N3 | |
| PA | PB |
| PLOADXG | 3 | 20 | 11 | 13 | 82 | 1.0 | 0.0 | 0.0 | |
| 10.5 | 12.5 |
| SID | Load set identification
                                    number. No default (Integer > 0)  |
| EID | Element identification
| PA | Surface traction at grid
                                point GA. No default (Real)  |
| PB | Surface traction at grid
                                point GB. No default (Real)  |
| GA, GB | Identification numbers of
                                two adjacent corner grid points on the element side. No default (Integer > 0)  |
| CID | Coordinate system
                                identification number. A CID of zero or blank
                                identifies the basic coordinate system.  Default = 0 (Integer ≥ 0, or blank)  |
| N1, N2, N3 | Components of a vector
                                measured in the coordinate system specified by
                                    CID. The vector defines the direction of the
                                load and is normalized internally such that it does not contribute
                                to the magnitude of the load. If N1,
                                    N2 and N3 are all blank,
                                the in-plane inward normal is used as default.  Default = In-plane inward normal (Real or all blank)  |
- The surface traction is assumed to
                    vary linearly along the element side between GA and
                        GB.
Figure 1. PLOADXG Definition
 - The surface traction is input as force per unit area.
