PLOADX1
Bulk Data Entry Defines a static surface traction on the CQAXI, CTAXI, CTRIAX6, CQAXIG and CTAXIG axisymmetric elements. The PLOADX1 entry can be defined as follower loads in Large Displacement Nonlinear Analysis.
| PLOADX1 | SID | EID | PA | PB | GA | GB | Theta |
| PLOADX1 | 3 | 20 | 10.5 | 12.5 | 11 | 13 | 15.0 |
| SID | Load set
                                    identification number. (Integer > 0)  |
| EID | Element identification
| PA | Surface traction at
                                    grid point GA. No default (Real)  |
| PB | Surface traction at
                                    grid point GB. Default = PA (Real or blank)  |
| GA, GB | Identification numbers
                                    of two adjacent corner grid points on the element side. No default (Integer > 0)  |
| Theta | Angle between surface
                                    traction and inward normal to the line segment. Default = 0.0 (Real or blank)  |
- The surface traction is assumed to vary linearly along the element side between GA and GB.
 - The surface traction is input as force per unit area.
 - The direction of the surface traction is
                    within the plane defined by the element cross-section.
                    "Theta" is measured counter-clockwise from the inward normal
                    of the straight line between GA and GB, to
                    the vector of the applied load, as shown in Figure 1.
                    Positive pressure is in the direction of inward normal to the line segment.
Figure 1. Pressure Load on CTRAX6 and CTAXI Elements
 - This card is represented as a pressure load in HyperMesh.
