PHFSHL
Bulk Data Entry Defines the thickness, material, blank holder, binder and Forming Limit Curve references for a shell property in a one-step stamping simulation.
| PHFSHL | PID | MID | T | BHID | FLDID |
| PHFSHL | 1 | 1 | 0.01 | 6 | 2 |
| PID | Unique shell element
                                    property identification number. No default (Integer > 0)  |
| MID | Material
                                    identification number of a MATHF entry. No default (Integer > 0)  |
| T | Thickness No default (Real > 0.0)  |
| BHID | Blank holder ID
                                    referring to a BLKHDF
                                        entry. No default (Integer > 0 or blank)  |
| FLDID | User-defined Forming
                                    Limit Curve identification number referring to FLDATA entry. No default (Integer > 0 or blank)  |
- This entry is only valid with an @ HyperForm statement in the first line of the input file.
 - All shell element property entries must have unique identification numbers.
 - PHFSHL is referenced by CTRIA3 and CQUAD4 entries.
