PFPATH
I/O Options and Subcase Information Entry The PFPATH command can be used in the I/O Options section for Transfer Path Analysis for a response at the connection points.
PFPATH (peakout) = SID
| Argument | Options | Description |
| peakout | <PEAKOUT> | If PEAKOUT is present as an option inside the parentheses of the PFPATH card, the filtered frequencies from the PEAKOUT are considered for output of transfer path results. |
| SID | No default (Integer > 0)  |
                                SID references a PFPATH card in the Bulk Data Section. |
