PELASFX
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
This property is not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
| PELASFX | PID | K | GE | S | PID | K | GE | S |
| PELASFX | 7 | 4.29 | 7.92 | 27 | 2.17 |
| PID | Unique scalar elastic property identification
                                                  number. No default (Integer > 0)  |
| K | Elastic property value. No default (Real)  |
| GE | Damping coefficient. To obtain the damping coefficient GE,
                  multiply the critical damping ratio,
                    , by 2. GE is ignored in transient analysis, if PARAM, W4 is not specified. Default = 0.0 (Real)  |
| S | Stress coefficient. Default = 0.0 (Real)  |
- Be careful using negative spring values.
 - One or two elastic spring properties may be defined on a single entry.
 - The
          element force of a spring is calculated from the equation:Where,
- Stiffness coefficient for the scalar element.
 - Displacement of the first degree-of-freedom listed on the CELAS1 and CELAS3 entries.
Element stresses are calculated from the equation:
Where, is the stress coefficient as defined above. - This card is represented as a property in HyperMesh.
