PARAM, VREF
Bulk Data Entry Used in aeroelastic flutter analysis to specify a factor to divide the velocities.
| Parameter | Values | Description |
| VREF | Value of the factor Default = 1.0 (Real > 0)  |
                                The velocities are divided by the value specified in this parameter to convert units or to compute flutter indices. |
