PARAM, TRAKMETH
Bulk Data Entry Used to select the criterion employed for mode tracking.
| Parameter | Values | Description |
| TRAKMETH | <0,
                                    1, 2> Defaults:
                            TRAKMETH is a parameter that can be used to
                                This
                                can also be controlled via the MODTRAK
                                Bulk Data Entry. There are three tracking
                                    criteria available for selection in the current implementation:
- PARAM, MODETRAK, YES or the subcase selector MODTRAK = YES or SID should be added to the input file to activate mode tracking.
