PARAM, GE_MOD
Bulk Data Entry Modifies specified GE values.
| Parameter | Values | Description |
| GE_MOD | <Real or
                                    NO_GE> No default  |
                            The real value of
                                    GE_MOD overrides the value of
                                    GE specified in all MATx
                                material data, sets the table ID for
                                    GE on the MATTx material
                                data to zero, and overrides the value of GE
                                specified on the PCOMP,
                                PCOMPP, and PCOMPG data.
                                    GE_MOD can be set to 0.0 to remove all
                                material-based structural damping from the model. The damping from
                                    PARAM, G will also be
                                applied when GE_MOD is
                                        present. NO_GE is used to remove all structural damping from the model. When NO_GE is specified, the value of GE will be set to zero on all MATx material data and the GE values specified in the CELAS2, PELAS, PELAST, PBUSH, PBUSHT, PCOMP, PCOMPP, and PCOMPG data will also be set to zero. In addition, the table ID for GE on MATTx material data will be set to zero. PARAM, G can be used to set the value to a constant value for the entire structure.  |
- PARAM, GFL should be used to replace the GE field on Fluid Material entries (MATx) instead of PARAM, GE_MOD.
