PARAM, ERPRLF
Bulk Data Entry The Radiation Loss Factor used in ERP calculation.
| Parameter | Values | Description |
| ERPRLF | Real > 0.0 Default = 1.0  |
                                used in the ERP calculation: |
- For a particular panel, the Loss Factor specified in the ERPRLF field on the PANELG Bulk Data Entry overrides the value specified in PARAM, ERPRLF.
