PARAM, CP2
Bulk Data Entry Scale factor for direct input load matrices.
| Parameter | Values | Description |
| CP2 | <Real> Default = 1.0  |
                            CP2
                                specifies factors for the direct input load matrix. The total load
                                matrix is: Where,
