PARAM, AUNITS
Bulk Data Entry Converts accelerations specified in units of gravity on the TRIM Bulk Data Entry to units of distance per time squared.
| Parameter | Values | Description |
| AUNITS | <REAL> Default = 1.0  |
                                Accelerations are divided by this parameter. To convert accelerations input in g’s into physical, consistent units, set PARAM,AUNITS to 1/g.  |
