OUTFILE
I/O Options and Subcase Information Entry Used in the I/O Options section to define the prefix for the results files output.
OUTFILE = option
| Argument | Options | Description |
| option | <file
                                    prefix> Default = passed in from the command line.  |
- Prefixes specified on the OUTFILE
                    card can be arbitrary file prefixes with optional paths appropriate to the
                    operating system (Windows or Unix). They may be
                    enclosed in quotes (double or single quotes can be used), and either forward
                    slash (/) or back slash (\) characters can be used to separate parts of the path
                    name. The following rules are used for the OUTFILE card:
- When the argument contains an absolute path of the file (if it starts with "/" on Unix or a drive letter, such as "D:", on Windows, for example), output files are created at the given location.
 - When only the file prefix is given (without the path), output files will be created in the current directory, meaning the directory from which the solver has been executed, and not in the directory where the input file is located.
 - When the argument contains a relative path (../filename or sub/filename, for example), output is created in a directory relative to where the solver is executed and NOT relative to the directory where the input file is located.
 - The total length of information on this card is limited to 620 characters (including the card name and spaces between arguments). This data can be on a single line or span multiple continuation lines. Refer to I/O Options and Subcase Information Entries Guidelines for an example showing how to enter long file names on multiple lines.
