Domain Decomposition Method
Domain Decomposition Method (DDM) is available for analysis and optimization. DDM is a parallelization option in OptiStruct that can help significantly reduce model runtime with improved scalability compared to legacy shared memory parallelization approaches, especially on machines with a high number of cores (for example, greater than 8).
DDM allows two main levels of parallelization depending on the attributes of the model.
DDM Level 1 – Task-based parallelization
-np=4) which are divided into 3 groups. This is an example of how grouping can be accomplished to parallelize a
                        model with multiple parallelizable tasks in DDM Level 1
| Supported Solutions | Task-based Parallelizable Entities in DDM | Non-Parallelizable Tasks |
| Linear Static Analysis | √ Two or more static Boundary Conditions are parallelized
                                    (Matrix Factorization is the step that is parallelized since it
                                    is computationally intensive). √ Sensitivities are parallelized for Optimization.  |
                                √ Iterative Solution is not parallelized. (Only Direct Solution is parallelized). |
| Buckling Analysis | √ Two or more Buckling Subcases are parallelized. √ Sensitivities are parallelized for Optimization.  |
| Direct Frequency Response Analysis | √ Loading Frequencies are parallelized. | √ Optimization is not parallelized. |
| Modal Frequency Response Analysis | √ Different modal Spaces are parallelized. | √ Optimization is not parallelized. |
| DGLOBAL Global Search Optimization with multiple starting points | √ Starting Points are parallelized. | |
| Multi-Model Optimization | √ Models listed in the main file are parallelized depending
                                    on the number of specified -np overall and/or
                                    the number of -np defined for each model in the
                                    main file. |
                                √ Task-based parallelization is not applicable within each MMO model. Only Geometric partitioning (DDM level 2) is conducted for each individual model in MMO. |
DDM Level 2 – Parallelization of Geometric Partitions
The second level of parallelization occurs at the distributed task level. Each distributed task can be further parallelized via Geometric partitioning of the model. These geometric partitions are generated and assigned depending on the number of MPI groups and the number of MPI processes in each group.
The second level DDM process utilizes graph partition algorithms to automatically partition the geometric structure into multiple domains (equal to the number of MPI processes in the corresponding group). During FEA analysis/optimization, an individual domain/MPI process only processes its domain related calculations. Such procedures include element matrix assembly, linear solution, stress calculations, sensitivity calculations, and so on.
-np=5) . The model has 3 task attributes (Example, 3 buckling subcases, or 3
                            DFREQ loading frequencies, etc). PARAM,
                            DDMNGRPS,2 is defined
-np=6). The MMO setup has 2 models. PARAM,DDMNGRPS should not
                        be used in conjunction with MMO
The DDM functionality for level two parallelization is direct geometric partitioning of a model based on the number of MPI processes available in the MPI group that is assigned to this task.
DDM level 2 is purely geometric partitioning and you can enforce only level 2 DDM by setting PARAM,DDMNGRPS,MIN. This minimizes the number of groups that can be assigned for the specified model, thereby leading to a pure geometric partitioning parallelization.
Hybrid DDM parallelization using both Level 1 and Level 2 parallelization is possible
                by setting
                    PARAM,DDMNGRPS,AUTO or
                    PARAM,DDMNGRPS,#, where
                    # is the number of MPI groups. In case of
                AUTO, which is also the default for any DDM run, OptiStruct heuristically assigns the number of MPI groups for
                a particular model, depending on model attributes and specified
                -np.
-np and the number of MPI groups.
                    PARAM,DDMNGRPS,<ngrps>
                is an optional parameter and AUTO is always the default for any DDM
                run. The model is first divided into parallelizable tasks/starting points (refer to
                    Table 1 for supported solution sequences for level 1).
                Each task/starting point is then solved sequentially by an MPI group. Each MPI group
                consists of one or more MPI Processes. If an MPI group consists of multiple MPI
                processes, then the task/starting point is solved by geometric partitioning in that
                MPI group (the number of MPI processes in a group is equal to the number of
                geometric partitions. Refer to Supported Solution Sequences for DDM Level 2 Parallelization (Geometric Partitioning) for solutions that
                support geometric partitioning level 2 DDM).- In the case of Global Search Option, the MPI process groups should not be confused with the number of groups (NGROUP) on the DGLOBAL entry. They are completely different entities and do not relate to one another.
 - In the case of Global Search Option, each MPI process prints the detailed report of the starting points processed and the summary is output in the .out file of the main process. The naming scheme of the generated folders is similar to the serial GSO approach (each folder ends with _SP#_UD#, identifying the Starting Point and Unique Design numbers).
 - PARAM,DDMNGRPS should not be used
                            in conjunction with Multi-Model Optimization (MMO) runs. For MMO, DDM
                            level 1 (task-based parallelization) is automatically activated when
                            specified np is greater than number of models plus 1 (or if number of
npfor each model is explicitly defined in the main file). DDM Level 1 for MMO simply distributes the extra MPI processes to models evenly. DDM Level 2 parallelization is geometric partitioning of each model based on the number of MPI processes assigned to each one. For more information, refer to Multi-Model Optimization.
-np 2
                            -ddm with
                            PARAM,DDMNGRPS,MAX
                        (assign geometric partitions/starting points to DDM MPI processes,
                        sequentially)
-np 4
                            -ddm, and
                            PARAM,DDMNGRPS,2
                        (assigns 3 Buckling subcases/starting points to DDM MPI groups,
                        sequentially. Subsequently, geometric partitioning is done within each MPI
| Solution | Activation | Level 1 | Level 2 | Grouping |
| Parallel Global Search Option (DDM) | Use -np # -ddmDefault is Hybrid DDM with PARAM,DDMNGRPS,AUTO PARAM,DDMNGRPS,<ngrps> is optional  |
                                Starting points are parallelized (each starting point is solved sequentially in a MPI process, if multiple starting points are assigned to 1 MPI process). | A Starting point is geometrically partitioned and solved in parallel by an MPI group (if the MPI group contains multiple MPI processes). | Grouping via
                                        PARAM,DDMNGRPS,AUTO
                                    is the default. If you need to adjust number of MPI groups, use
                                    (if np> ngrps then this activates 2nd level
                                    parallelization wherein geometric partitioning of some/all
                                    starting point run(s) occurs when multiple MPI processes can
                                    operate on a single starting point). |
| General Analysis/Optimization runs (DDM) | Use -np # -ddmDefault is Hybrid DDM with PARAM,DDMNGRPS,AUTO. PARAM,DDMNGRPS,<ngrps> is optional.  |
                                Loadcases, loading Frequencies (Task-based parallelization) Refer to Table 1 for supported solutions). | Each loadcase/loading frequency is geometrically partitioned and solved in parallel by an MPI group (if the MPI group contains multiple MPI processes). | Grouping via
                                        PARAM,DDMNGRPS,AUTO
                                        PARAM,DDMNGRPS,<ngrps> Like
                                        the above scenario, if   |
| Multi-Model Optimization (MMO) with DDM | Use -np #
                                            -mmoPARAM,DDMNGRPS is not supported with MMO  |
                                Optimization models are parallelized wherein extra MPI
                                    processes (> no of models plus 1) are distributed evenly to
                                    models in main MMO file (or user- defined -np
                                    for each model in main file). |
                                Any MMO optimization model is geometrically partitioned and solved in parallel (number of partitions depends on number of MPI processes/np assigned to it). | There is no grouping via PARAM,DDMNGRPS as it is not supported for MMO. However, grouping is indirectly accomplished by automatic distribution of np to the MMO models or by explicit user input via Main file. |
| DDM Level | Supported Solutions | ||
| Domain Decomposition (Level 2) | Linear Static Analysis and Optimization | Nonlinear Static analysis | Linear Buckling Analysis and Optimization (MUMPS is available for SMP) |
| Fatigue Analysis (based on Linear Static, Modal Transient, Random Response) | Normal Modes (with Lanczos) | Modal Frequency Response (with Lanczos) | |
| Preloaded Modal Frequency Response (with AMLS/AMSES) Only preloading static subcase is parallelized.  |
                                Nonlinear Transient Analysis | Direct Linear Transient Analysis | |
| Modal Linear Transient Analysis | Structural Fluid Structure Interaction (Structural FSI) | Multi-Model Optimization (MMO) | |
| Direct Frequency Response Analysis (Structural, Acoustic, and MFLUID) (MUMPS is available for SMP) | Nonlinear Steady-State Heat Transfer Analysis | Nonlinear Transient Heat Transfer Analysis | |
| Periodic Boundary Conditions (PERBC) | |||
Iterative solver are currently not supported in conjunction with DDM.
- The
-ddmrun option can be used to activate DDM. Refer to How many MPI processes (-np) and threads (-nt) per MPI process should I use for DDM runs? for information on launching Domain Decomposition in OptiStruct. - In DDM mode, there is no distinction between MPI process types (for
                            example, manager, main, secondary, and so on). All MPI processes
                            (domains) are considered as worker MPI processes. Additionally, hybrid
                            DDM with multiple levels is the default for any DDM run. Therefore, if
-np nis specified, OptiStruct first divides available-npinto MPI groups heuristically (PARAM,DDMNGRPS,AUTO) and then within each MPI group, subsequent geometric partitions are conducted wherein the number of such partitions in each group are equal to the number of MPI processes available in that group. These MPI processes are then run on corresponding sockets/machines depending on availability. - Hybrid computation is supported.
-ntcan be used to specify the number of threads (m) per MPI process in an SMP run. Sometimes, hybrid performance may be better than pure MPI or pure SMP mode, especially for blocky structures. It is also recommended that the total number of threads for all MPI processes (n x m) should not exceed the number of physical cores of the machine.
Known Issues
MPI run on Linux may error out due to an
                    ssh error.
Error :/bin/ssh:
$ALTAIR_HOME/altair/hwsolvers/common/python/python3.5/linux64/lib/libcrypto.so.10:
version OPENSSL_1.0.2 not found (required by /bin/ssh)This can occur when the libcrypto library from Python conflicts with
                the one required by MPI. To resolve this, copy libcrypto from the
                system to the location mentioned in the error above. In the system, this library is
                typically in /usr/lib64.
