NOLIN4
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
Where, may be a displacement or a velocity at point GJ in the direction of CJ.
| NOLIN4 | SID | GI | CI | S | GJ | CJ | A |
| NOLIN4 | 2 | 4 | 6 | 2.0 | 101 | 16.3 |
| SID | Nonlinear load set
                                    identification number. No default (Integer > 0)  |
| GI | Grid or scalar point
                                    identification number at which nonlinear load is to be
                                        applied. No default (Integer > 0)  |
| CI | Component number for
                                        GI. No default (1 ≤ Integer ≤ 6; blank or 0, if GI is a scalar point)  |
| S | Scale factor. No default (Real)  |
| GJ | Grid or scalar point
| CJ | Component number for GJ, GK according to the following table. | |
| A | Exponent of the
                                    forcing function. No default (Real)  |
| Type | Displacement | Velocity |
| Grid | 1 ≤ Integer ≤ 6 | 11 ≤ Integer ≤ 16 |
| Scalar | Blank or 0 | Integer = 10 |
- Nonlinear loads must be selected by the Subcase Information data selector NONLINEAR.
 - Nonlinear loads may not be referenced on a DLOAD entry.
 - All degrees-of-freedom referenced on NOLIN4 entries must be members of the solution set.
 - Nonlinear loads may be a function of
                    displacement
                         or velocity
                        . Velocities are denoted by components ten
                    greater than the actual component number; that is the component 11 indicates
                    velocity in the 1 component direction. The velocity is determined
                        by:Where,
- Time step interval
 - Displacement of GJ-CJ for the previous time step.
 - Use a NOLIN3 entry for the positive range of .
 - The time step algorithm in transient solution sequences may loose unconditional stability when this load entry is used. In most practical cases, the time step size chosen to reach a certain accuracy is below the stability limit. It is recommended to decrease the time step if results diverge.
