NLDEBUG, RMNLMAT
I/O Options and Subcase Information Entry This parameter ignores nonlinear materials specified in the model.
| Parameter | Description |
| RMNLMAT | Setting this parameter
                                    ignores nonlinear materials specified in the model. Typically,
                                    certain nonlinear materials are completely ignored while other
                                    nonlinear materials are linearized.
- This parameter can only be specified in the global subcase section (above all the subcases).
 - This parameter does not require a value to be specified.
