NLDEBUG, NLP2NLC
I/O Options and Subcase Information Entry This parameter converts an NLPARM-based setup to an NLCTRL-based setup in a nonlinear model.
| Parameter | Description |
| NLP2NLC | Setting this parameter
                                    When NLPARM (and additionally
                                        NLADAPT, if any) entries are defined in
                                    nonlinear models, they are converted internally to
                                        NLCTRL.
- This parameter can only be specified in the global subcase section (above all the subcases).
 - This parameter does not require a value to be specified.
 - This conversion is conducted after ECHO; if the input deck is echoed out with the ECHO command, the original NLPARM (and optional NLADAPT)-based setup is echoed out.
