MOTNJG
Bulk Data Entry Defines motion for joint connector JOINTG Bulk Data Entry.
| MOTNJG | ID | TID | TSTIME | ||||||
| JID1 | DOF | VALUE | |||||||
| JID2 | DOF | VALUE | |||||||
| etc. |
| MOTNJG | 3 | ||||||||
| 2 | 1 | 1.0 | |||||||
| 3 | 2 | 2.0 |
| ID | Motion set identification
                                    number. (Integer > 0)  |
| TID | Identification number of a
                                    TABLEDi entry that defines motion scale
                                factors versus time. The motion in the VALUE
                                field is multiplied with the scale factors to determine
                                time-dependent motion on the joint degrees of freedom. Default = blank (Integer > 0)  |
| TSTIME | Switch for time duration
                                of the data from the table defined in TID. 3
 Default = TOT  |
| JIDi | Identification number of a JOINTG Bulk Data Entry on which the motion is to be applied. | |
| DOF | Degree of freedom
                                component number. No default (1 ≤ Integer ≤ 6)  |
| VALUE |
 No default  |
- The MOTNJG Bulk Data Entry can be referenced in the corresponding MOTNJG Subcase Information Entry.
 - If a MOTNJG Bulk Data Entry is not referenced in any subcase, then it is not used in the solution.
 - TID and
                        TSTIME are supported for:
- Implicit small and large displacement nonlinear static analysis.
 - Implicit small and large displacement nonlinear transient analysis.
 - Explicit dynamic analysis.
