MONVOL
Bulk Data Entry Defines a one-chamber gas filled structure with hybrid input of inflated gas in explicit dynamic analysis or a cavity filled with fluid in implicit large displacement analysis.
| MONVOL | MID | UNIT | |||||||
| SURF | SID | ||||||||
| AMBIENT | PATM | TATM |
| IAIR | PAIR | TAIR | |||||||
| XMAIR | Cpa_air | Cpb_air | Cpc_air | Cpd_air | Cpe_air |
| + | VENT | SIDV | C23 | LCTC23 | LCPC23 | PDEF |
| + | MATGAS | LCM | LCT | ||||||
| XM |
| + | HYDRA | BULK |
| + | IAIR | PAIR |
| MONVOL | 1 | ||||||||
| SURF | 10 | ||||||||
| AMBIENT | 1.013E5 | 293.0 | |||||||
| MATGAS | 3 | 4 | |||||||
| 0.004 | 40.0 | 0.0 | 0.0 | ||||||
| IAIR | 1.013E5 | 293.0 | |||||||
| 0.028 | 28.0 | 0.0 | 0.0 |
| MID | Monitor volume identification number. No default (Integer > 0)  |
| UNIT | Unit system.
| SURF | Flag to indicate the external surface of enclosed volume. | |
| SID | External surface identification defined by a set of
                                        elements. No default (Integer > 0)  |
| ATM | Flag to indicate that the two following fields define atmospheric pressure and temperature. | |
| TATM | Ambient temperature. Default=293 K (Real ≥ 0.0)  |
| PATM | Ambient pressure. Default=1 atm (Real ≥ 0.0)  |
| VENT | Flag to indicate that the following five fields indicate the vent hole properties. | |
| SIDV | Vent hole area surface identification number. No default (Integer > 0)  |
| C23 | Scale factor on vent hole area. Default=1.0 (Real > 0.0)  |
| LCTC23 | Curve defining vent hole coefficient as a function of
                                        time. No default (Integer > 0)  |
| LCPC23 | Curve defining vent hole coefficient as a function of
                                        pressure. No default (Integer > 0)  |
| PDEF | Pressure difference between interior and ambient pressure to
                                    open vent hole. Default=0.0  |
| MATGAS | Flag to indicate that the following four fields define the inflated gas properties. | |
| LCM | Table that defines mass flow rate curve for the gas component. | |
| LCT | Table that defines temperature curve for the gas component. | |
| XM | Molar mass of the gas component. | |
| Cpa, Cpb, Cpc, Cpd, Cpe | Molar heat capacity coefficients of the inflow gas at constant pressure. 4 | |
| IAIR | Flag to indicate that the following four fields define properties of the initial gas inside the structure. | |
| PAIR | Initial pressure inside
                                            structure. Default=PATM (Real ≥ 0.0)  |
| TAIR | Initial temperature inside
                                            structure. Default=TATM (Real ≥ 0.0)  |
| XMAIR | Molar mass of air initially inside structure. No default (Real ≥ 0.0)  |
| Cpa_air, Cpb_air, Cpc_air, Cpd_air, Cpe_air | Molar heat capacity coefficients of the initial air at
                                    constant pressure. 4 No default (Real ≥ 0.0)  |
| HYDRA | Flag to indicate that the following fields define properties of incompressible/compressible fluid (implicit large displacement analysis only. Otherwise, the definition is ignored in analysis). 5, 6 | |
| BULK | Bulk modulus of compressible fluid inside structure If this
                                    is BLANK, the fluid inside the structure is
                                        incompressible. Default = BLANK (Real ≥ 0.0)  |
- The volume must be a completely enclosed volume and the norm must be oriented outwards. If the structure contains a vent hole, the vent hole must be meshed with a shell element.
 - The value of the total vent hole
                        coefficient must be between 0.0 and 1.0:
Total vent hole coefficient = min(max(C23 × LCTC23 × LCPC23, 0.0), 1.0).
 - There is no limit on the number of gas components.
 - Heat capacity at constant
                            pressure:
Where, is temperature.
 - MONVOL with HYDRA continuation line can be used in an implicit large displacement analysis to model a cavity filled with ideal gas/hydraulic fluid. An element set must be used to define a cavity filled with the fluid. In this case, a result item called “fluid cavity (s)” with 4 sub results namely volume, cavity pressure, applied pressure and energy is available in HyperView. These results are available in the regular or the on-the-fly .h3d file. MONVOL for implicit large displacement analysis is supported for first and second order solid, shell, plane strain (CQPSTN, CTPSTN) and axisymmetric (CQAXI, CTAXI, CTRIAX6) elements.
 - In implicit large displacement
                        analysis, Boyle’s law is used in ideal gas, which is:
P*V = P0*V0
In a compressible fluid case, the constitutive relation of the fluid is written as:p = B*(V-V0)/V0
Where,- B
 - Bulk modulus
 - V
 - Current volume of the cavity
 - V0
 - Initial volume of the cavity
 - p
 - Applied pressure
 - Support information for
                            MONVOL:
- Supported Analysis Types
 - Explicit Dynamic Analysis
