MONPNT2
Bulk Data Entry Define an integrated load monitor point for specific elements and to output results for these elements.
| MONPNT2 | NAME | LABEL | |||||||
| TABLE | TYPE | NDDLitem | EID | ||||||
| MONPNT2 | PART12 | Stringer load | |||||||
| STRESS | CBAR | SX2A | 101 | ||||||
Definition
| NAME | Unique character string identifier for the monitor point.  No default (Character)  |
| LABEL | A character string that identifies and labels the monitor point.
                                     Up to 56 characters are supported. Default = blank (Character)  |
| TABLE | Type of the output to be monitored. 2
| TYPE | Type of the element to be monitored.  No default (Character)  |
| NDDLitem | Item code for the element type to be monitored.  List of supported elements and their codes can be found in the NDDL item code table. No default (Character)  |
| EID | ID of the element to be monitored.  No default (Integer > 0)  |
- The MONPNT2 entry is supported only for linear static and static aeroelastic analysis.
 - If invalid entities are specified in TABLE, TYPE, NDDLitems or EID fields, an error message will be issued.
 - The results requested by the MONPNT2 entry will be printed to the .monpnt file.
