MEFFSET
Bulk Data Entry This entry is used to group element sets for which MEFFMASS output is desired in HyperMesh set based format.
| MEFFSET | ID | ||||||||
| + | SETID1 | SETID2 | SETID3 | SETID4 | etc. | ||||
| + | etc. | SETIDi | etc. |
| + | 101 | 102 | 103 | 104 | 105 |
| ID | Unique identification
                                        number. This ID must match the SET in MEFFMASS definition. No default (Integer > 0)  |
| SETIDi | Element set ID. No default (Integer > 0)  |
- MEFFSET is only applicable with the MEFFMASS entry when output is desired in the form of element sets.
 - The output is printed to the .out file and also to an .effmass file ASCII format file.
