MCOHE
Bulk Data Entry Defines the material properties for potential-based cohesive material models.
| MCOHE | MID | MODEL | |||||||
| COHE | CRTOD | MAXOD | BETA | EXP | VED | SFC |
Example 1
| MCOHE | 2 | 1 | |||||||
| 20.0 | 0.02 | 0.2 | 1.0e5 |
Example 2
| MCOHE | 2 | 2 | |||||||
| 10.0 | 0.03 | 0.5 | 1.0e-3 | -1.0 |
Example 3
| MCOHE | 2 | 3 | |||||||
| 20.0 | 0.03 | 2.0 | 1.0e-4 | SOFT |
| MID | Material identification number. No default (Integer > 0)  |
| MODEL | Indicates the traction-separation
                  relationship profile type.
 No default (Integer)  |
| COHE | The energy per area that can be
                  absorbed by the cohesive elements. It is the area under the traction-separation
                  curve.  No default (Real > 0.0)  |
                or |
| CRTOD | Critical opening distance. No default (Real ≥ 0.0)  |
| MAXOD | Maximum opening displacement (bilinear
                  model only). No default (Real > 0.0)  |
| BETA | Coefficient on the shear opening for
                  mode mix based on displacement. Default = 1.0 (Real ≥ 0.0)  |
| EXP | Exponential decay factor
                  (linear-exponential model only). No default (Real > 0.0)  |
| VED | Viscous energy dissipation
                    factor. Default = 0.0. (Real > 0.0)  |
| SFC | Stiffening factor in compression.
 Default = -1.0  |
- The material identification number must be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, and MCOHED entries.
 - In some cases, snap-back phenomena could appear in numerical models with cohesive elements. VED can be used to stabilize the solution.
 - For additional information, refer to Cohesive Zone Modeling in the User Guide.
