MBMNT
Bulk Data Entry Defines a constant moment at a grid point by specifying a vector.
| MBMNT | SID | G1 | CID | M | G3/N | N | N | G2 |
| MBMNT | 3 | 345 | 100.0 | 0.0 | 1.0 | 0.0 |
| SID | Load set identification number. No default (Integer > 0)  |
| G1 | Grid point identification number where
                the action force is applied. No default (Integer > 0)  |
| CID | Coordinate system identification number.
                Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0, or blank)  |
| M | Moment magnitude. No default (Real)  |
| G3 | Grid point identification number to
                optionally supply N1, N2,
                  N3 in conjunction with G1. (Integer > 0)  |
| N,N,N | Defines the direction of the force
                vector. At least one of the vector components must be non-zero. Default = 0.0 (Real)  |
| G2 | Grid point identification number where
                the reaction force is applied. If blank or zero, the force is an action-only
                  force. Default = 0 (Integer ≥ 0)  |
- This card is represented as a moment load in HyperMesh.
