MBFRCE
Bulk Data Entry Defines an expression force at a grid point by specifying a vector.
| MBFRCE | SID | G1 | CID | EID | G3/N | N | N | G2 | |
| G4 |
| MBFRCE | 3 | 345 | 49 | 0.0 | 1.0 | 0.0 | |||
| 201 |
| SID | Load set identification
                                    number. No default (Integer > 0)  |
| G1 | Grid point identification
                                number where the action force is applied. No default (Integer > 0)  |
| CID | Coordinate system
                                identification number. Blank or 0 infer the basic coordinate
                                    system. Default = 0 (Integer ≥ 0, or blank)  |
| EID | Expression identification
                                number of the MBVAR entry that gives the load
                                measured in the coordinate system defined by
                                    CID. No default (Integer > 0)  |
| G3 | Grid point identification
                                number to optionally supply N1,
                                    N2, N3 in conjunction with
                                    G1. (Integer > 0)  |
| N, N, N | Defines the direction of
                                the force vector. At least one of the vector components must be
                                    non-zero. Default = 0.0 (Real)  |
| G2 | Grid point identification
                                number where the reaction force is applied. If blank or zero, the
                                force is an action-only force. Default = 0 (Integer ≥ 0)  |
| G4 | Grid point identification
                                number whose parent body hosts the coordinate system with respect to
                                which the force is defined. The force vector changes direction with
                                the orientation of the body. If undefined, the force is defined with respect to the ground body (that is the basic coordinate systems). Default = blank (Integer ≥ 0 or blank)  |
