MBCVCV
Bulk Data Entry Defines a Curve to Curve Constraint.
| MBCVCV | JID | blank | PCID1 | G3 | V1 | ||||
| blank | blank | PCID2 | G4 | V2 |
| MBCVCV | 1 | 1 | 0 | 0 | |||||
| 2 | 0 | 1 |
| JID | Joint identification
                                    number. No default (Integer > 0)  |
| PCID1 | Parametric curve
                                    (MBPCRV) identification number. No default (Integer > 0)  |
| PCID2 | Parametric curve
| G3 | This grid specifies the
                                guess for the initial contact point on the first curve. Although this parameter is optional, specifying it helps the solver in determining the initial contact point.  |
| V1 | Specifies the sliding
                                velocity of the contact point relative to the part on which the
                                curve is etched. V1 is positive when contact
                                point is moving toward the start of the curve and
                                    vice-versa. Default = 0.0 (Real)  |
| G4 | This grid specifies the
                                guess for the initial contact point on the second curve. Although this parameter is optional, specifying it helps the solver in determining the initial contact point.  |
| V2 | Specifies the sliding
                                curve is etched. V2 is positive when contact
