MBCNTDS
Bulk Data Entry Defines a Multibody Contact between a set of nodes and a deformable surface.
| MBCNTDS | CID | SID | SRFID | CNFTYPE | STIFF | DAMP | RADIUS |
| MBCNTDS | 2 | 21 | 4 | LINEAR | 1E6 | 10 | .1 |
| CID | Contact identification number. No default (Integer > 0)  |
| SID1 | Set identification number of a set of
                  nodes. No default (Integer > 0)  |
| SRFID | Multibody deformable surface
                  (MBDSRF) identification number. No default (Integer > 0)  |
| CNFTYPE | Contact normal force type.
 No default (Character)  |
| STIFF | Specifies the interface stiffness
                coefficient, if  CNFTYPE=LINEAR, Specifies the penalty parameter which is related to the stiffness RJTODO, if CNFTYPE=POISSON. Default = 0.0 (Real ≥ 0.0)  |
| DAMP | Specifies the interface damping, if
                  CNFTYPE=LINEAR. Default = 0.0 (Real ≥ 0) Specifies the coefficient of restitution value for the contact, if CNFTYPE=POISSON. Default = 1.0 (0.0 ≤ Real ≤ 1.0)  |
| RADIUS | Radius of the sphere geometry centered
                at the origin of the I marker. Default = 0.0 (Real ≥ 0)  |
- This card is represented as a group in HyperMesh.
