MATTVE
Bulk Data Entry Defines material properties for temperature-dependent nonlinear viscoelastic materials.
Format A
Williams-Landel-Ferry (Model = WLF):
| MATTVE | MID | Model | C | C | T0 |
Format B
Arrhenius (Model = ARRHENIU):
| MATTVE | MID | ARRHENIU | E | R | T0 | Tz |
Example A
| MATTVE | 2 | WLF | 4.0 | 215.0 | 10.0 |
Example B
| MATTVE | 2 | ARRHENIU |
| MID | Material identification
                                number that matches the identification number of the corresponding
                                    MAT1 entry. No default (Integer > 0)  |
| Model | Viscoelastic material
                                model type.
 No default  |
| C | WLF constant C. Default = Blank (Real > 0.0)  |
| E | Activation energy for the
                                Arrhenius model. No default (Real > 0.0)  |
| R | Universal gas
                                    constant. No default (Real > 0.0)  |
| T0 | Reference
                                    temperature. No default (Real)  |
| Tz | Absolute zero
- Support information for MATTVE is:
Supported Analysis Types Supported Elements Nonlinear static and Nonlinear transient, for both small and large displacement cases CHEXA, CTETRA, CPENTA, CPYRA, CQUAD4, and CTRIA3  - The temperature effect on the viscoelastic material is introduced by
                        the thermo-rheologically simple temperature effects:Where,
- The reduced time given by:
- Shift function
 - Temperature
 - For temperature-dependent material table lookup for an element with different temperatures at each node, the average temperature of all nodes of the element is considered as reference temperature for table lookup for that particular element.
 - Two forms of shift functions are supported:
- Williams-Landel-Ferry form
 - Arrhenius form
