MATT2EC
Bulk Data Entry Defines temperature-dependent material properties for the corresponding MAT2EC Bulk Data Entry fields via TABLEMi or TABLEG entries.
| MATT2EC | MID | T( XX) | T( YY) | T( ZZ) | |||||
| T(JH) |
| MATT2EC | 24 | 200 | 110 | 150 | |||||
| 101 |
| MID | Material identification number of a
                                        MAT5 Bulk Data Entry that is temperature
                                    dependent.  No default (Integer > 0)  |
| T( ij) | Identification number of a
                                        TABLEMi or TABLEG
                                    entry that defines the individual elements of the
                                    temperature-dependent electric conduction matrix, along each
                                    direction.  Default = 0 (Integer ≥ 0)  |
| T(JH) | Identification number of a
                                        TABLEMi or TABLEG
                                    entry that defines temperature-dependent Joule heating fraction.
- The quantities defined on the MAT2EC Bulk Data Entry are multiplied by the tabular function referenced by the MATT2EC Bulk Data card to generate the corresponding material properties.
 - For temperature-dependent material table lookup for an element with different temperatures at each node, the average temperature of all nodes of the element is considered as reference temperature for table lookup for that particular element.
 - If the fields are blank or zero, constant properties defined on the MAT2EC Bulk Data card are used.
