MATMDS
Bulk Data Entry Defines material properties and parameters through an interface to Altair Multiscale Designer® allowing you to include a much wider range of different material models.
| MATMDS | MID | AMAT | OPTION | AOPT |
ASSIGN,MATMDS,USRMAT,D:/mymaterial.dat
| MATMDS | 32 | USRMAT | FIBER | FIBMAT |
| MID | Each
                                        MATMDS Bulk Data Entry should have a
                                    unique ID. No default (Integer > 0)  |
| AMAT | Identifies the name of
                                    the ASSIGN entry which identifies the
                                        Multiscale Designer material file. No default (<Character String>)  |
| OPTION | Identifies the entity
                                    to which the subsequent material is applied.
| AOPT | Identifies the name of
                                        Multiscale Designer material file for the
                                    specified entity in the OPTION
                                        field. Default = blank (<Character String> or blank)  |
- MATMDS is
                        available to interface OptiStruct with Multiscale Designer to include a much wider range of different
                        material models.
Multiscale Designer is an efficient tool for development and simulation of multiscale material models of continuous, woven, and/or chopped fiber composites, honeycomb cores, reinforced concrete, soil, bones, and various other heterogeneous materials.
Applications include multiscale material modeling for design, ultimate failure, statistical- based material allowables, fatigue, fracture, impact, crash, environmental degradation, and multiphysics simulations and provides plugins to commercial FEA solvers OptiStruct and Radioss.- Develop multiscale material models using forward homogenization and inverse optimization technologies
 - Built-in parametric unit cells for unidirectional, woven, chopped, and particulate fiber composites
 - Simulate nonlinear material behavior including ultimate failure at the micro-scale
 - Obtain virtual material allowables supported by test and perform fatigue analysis
 - Efficient plug-ins to commercial FEA codes OptiStruct and Radioss
 - Material model data files from Multiscale Designer can be located anywhere on the machine and can be identified using the ASSIGN,MATMDS command.
 - If the MATMDS entry is specified, then OptiStruct looks for the Multiscale Designer installation within the same Mechanical Solvers installation from which the OptiStruct run is initiated. The MDSDIR I/O Options Entry can also be used to specify the Multiscale Designer installation location, if it has been installed in a different location.
 - MATMDS is supported for both Shell and Solid elements.
