MATFATT
Bulk Data Entry Defined temperature-dependent material properties for fatigue analysis.
| MATFATT | MID | TEMPUNIT |
| TEMP | Ti | ||||||||
| SNTBL | REFTYPE | LogSE | Nc1 | Nc | FINDLEY | STSTYPE | |||
| REFVAL | A1 | B1 | A2 | B2 | A3 | B3 | |||
| A4 | B4 | A5 | B5 | etc. |
| MID | Material
                                    identification number that matches the identification number on
                                    a MAT1 Bulk Data Entry and the corresponding
                                        MATFAT entry.  No default (Integer > 0)  |
| TEMPUNIT | Temperature
                                        unit. Default = C (C, F)  |
| TEMP | Flag indicating that the temperature value follows. | |
| Ti | Temperature at which
                                    the corresponding Haigh diagram is defined. A single Haigh
                                    diagram can be defined at each temperature
                                        (Ti). No Default (Real)  |
| SNTBL | Flag indicating that X-Y data for a Haigh Diagram follows. | |
| REFTYPE | Reference type
                                    identifying the type of curve definition.
 Ai, Bi data below represents a single Haigh diagram. The life value for the Haigh diagram curve is identified via the REFVAL field. No default (LIFE)  |
| LogSE | Standard Error of
                                    log(Stress).  Default = 0.0 (Real > 0.0)  |
| Nc1 | Fatigue transition
                                    point. After this point, fatigue strength is offset by the
                                    surface correction factor. Before this point, fatigue strength
                                    is proportionally reduced. Default = NC (Real > Nc_stat)  |
| Nc | Endurance limit. Number
                                    of cycles at which damage can be considered zero.  Default = 1.0E+8 (Real > 1.0E+5)  |
| FINDLEY | Constant k in the
                                    Findley model. Default = 0.3 (Real > 0.0)  |
| STSTYPE | Stress type.
| REFVAL1 | Reference value of Life
                                    for which the Haigh Diagram is defined. No default (Real)  |
| Ai | Depending on STSTYPE, Ai values can be one of stress amplitude, stress range, or max stress. | |
| Bi | Depending on
                                        REFTYPE, Bi values can
                                    be life (REFTYPE=MEAN or
                                        RRATIO) or mean stress
                                        (REFTYPE=LIFE). No default  |
- The MID field of the MATFATT entry should match with a corresponding MATFAT entry (which is used to define basic information such as stress units and length) and a MAT1 entry.
 - Only a single Haigh diagram per temperature is currently supported. Therefore, only safety factor analysis is currently supported with MATFATT.
 - Static failure is currently not supported with the MATFATT Bulk Data Entry.
