User-Defined Structural Material
The MATUSR Bulk Data Entry, in combination with the LOADLIB I/O Option Entry, allows for the definition of structural material through user-defined external functions.
The external functions may be written in Fortran, C or C++. The resulting libraries and files should be accessible by OptiStruct regardless of the coding language, provided that consistent function prototyping is respected, and adequate compiling and linking options are used.
Write External Functions
Two Fortran subroutines are required to define user material in OptiStruct. First, a Nonlinear subroutine for the nonlinear large displacement solution, and another subroutine for the linear and nonlinear small displacement solution. Both subroutines are mandatory, and the same argument order should be followed as:
      subroutine usermaterial(idu,stress,
     $     strain,dstrain,dfgrOld,dfgrNew,
     $     stater,state,nstate,
     $     drot,
     $     props,nprops,ndi,nshear,ntens,temp,dtemp,
     $     ieuid,
     $     kinc,dt,t_step,t_total,
     $     cdev,cbulk)
integer idu, nstate, nprops, kinc, ieuid, ndi, nshear, ntens, ierr
double precision stress(6),stater(*),state(*),
     $     cdev(6,6),cbulk, drot(3,3), temp, dtemp, dt,
     $     t_step, t_total,
     $     strain(6), dstrain(6), props(nprops)
     $     dfgrOld(3,3),dfgrNew(3,3)
character*32000 userdatasubroutine smatusr(idu, nprop, prop, ndi, nshear, ntens, smat, userdata,  ierr)
integer idu, nprop, ndi, nshear, ntens, ierr
double precision prop(nprop), smat(*)
character*32000 userdatainitusr subroutine:subroutine initusr(idu,nstate,cstate)
      implicit none
      integer idu,nstate
      character*64 cstate(nstate)The strings in the initusr
                subroutine should always be declared as
                follows:      character*64 cstate(nstate)The declaration
                should always use 64-character size.cstate variable can be assigned the label to
                print in the user-defined results with 1 being the index for the
                first variable in the example
                    below:	cstate(1) = “Variable Name for State(1)”Subroutine Arguments
| Argument | Type | Input / Output | Description |
idu |
                                integer | Input | This is defined via the USUBID parameter
                                    on the MATUSR Bulk Data Entry. This argument
                                    can be used to define and choose between different types of
                                    materials within the same user subroutine.  optional use  |
stress |
                                double (table) | Input/Output | This is the Stress tensor. The initial stress is considered to be input and the stress, tensor calculated during the nonlinear solution are output from the user subroutine to OptiStruct. |
strain |
                                double (table) | Input | Strain tensor. The initial strain is considered to be input. |
dstrain |
                                double (table) | Input | Incremental strain table. The incremental strain is input from OptiStruct to the user subroutine. |
dfgrOld |
                                double (table) | Input | Deformation gradient tensor of the previous increment. This argument is currently supported for solid elements (PSOLID) or continuum shells (PCOMPLS). |
dfgrNew |
                                double (table) | Input | Deformation gradient tensor of the current increment. This argument is currently supported for solid elements (PSOLID) or continuum shells (PCOMPLS). |
stater |
                                double (table) | Input/Output | Table of State variables at the previous increment. |
state |
                                double (table) | Input/Output | Table of State variables at the current increment. See
                                        stater for more information. State
                                    variables are variables that can be requested as output in the
                                    H3D file. Any variable (for example, plastic strain, equivalent
                                    plastic strain, and so on) calculated within the solution
                                    process in the subroutine can be output by defining it as a
                                    state variable. The number of state variables can be specified
                                    via nstate. |
nstate |
                                integer | Input/Output | Number of State Variables that the user requires in the
                                    subroutine. These state variables are output in the H3D file.
                                    See stater for more information. This is
                                    specified via the NDEPVAR field of the
                                        MATUSR Bulk Data Entry. |
cstate |
                                string | Output | Output in the form of a string from initusr
                                    subroutine to OptiStruct. In the
                                        usermaterial or smatusr
                                    subroutines the state variable outputs any variable in the
                                        H3D file. The cstate
                                    variable provides the name of the state variable declared in
                                    that subroutine to display in the H3D
                                    file. |
props |
                                double (table) | Input | This table contains all the user-defined material property information from the PROPERTY continuation line of the MATUSR entry. |
nprops |
                                Integer | Input | This is the total number of material properties defined on the PROPERTY continuation line of the MATUSR entry. |
ndi |
                                Integer | Input | The number of normal stress components (3 for solid elements, 2 for shell elements). |
nshear |
                                Integer | Input | The number of shear stress components (3 for solid elements, 1 for shell elements). |
ntens |
                                Integer | Input | The number of tensor components (ntens =
                                        ndi + nshear). |
temp |
                                double | Input | This is the temperature at the previous converged increment. |
dtemp |
                                double | Input | This is the temperature increment. |
ieuid |
                                integer | Input | Element ID. This subroutine is called for every integration point for every element. |
kinc |
                                integer | Input | Current increment. |
dt |
                                double | Input | Current Time increment |
t_step |
                                double | Input | Subcase time. |
t_total |
                                double | Input | Total time (if CNTNLSUB is used) |
cdev |
                                double (table) | Output | Full material modulus matrix of size (6x6). These are calculated during the solution and are output to OptiStruct to form the stiffness matrix. |
cbulk |
                                double (table) | Output | (Optional) Bulk material modulus Matrix. |
smat |
                                Double (table) | Output | 1D array (21 terms). This is the symmetric part of
                                        cdev. These are calculated during the
userdata |
                                Character | Output | User-defined message that is output based on the value of
                                        ierr argument. |
ierr |
                                Integer | Input/Output | Flag that activates/deactivates Output message for an
                                        OptiStruct run from the user
                                        subroutine.
Build External Libraries for User-defined Materials
Allows building shared libraries on Windows or Linux.
Refer to Build External Libraries for more information.
