Material Property Checks for MAT3
MAT3 only applies to axisymmetric elements.
| Material Requirements | MAT3 |
| Mathematical | If EX = 0, ETH = 0, EZ = 0
                                    or NUXTH * NUTHX + NUTHZ * NUZTH + NUZX * NUXZ + 2 * NUXTH * NUTHZ * NUZX = 1, an error termination will occur. 1  |
| Semi-stability | If EX < 0, ETH < 0,
                                EZ < 0, GZX < 0, GXTH < 0, or GTHZ < 0, an error
                                termination will
                                        occur. PARAM,CHECKMAT,NO will disable this error.  |
| Not all zeros | If GZX = 0, a warning is provided. |
| Consistency | none |
- By substitution of
into
it can be expressed in terms of
