MAT2PT
Bulk Data Entry Defines anisotropic permittivity and damping for dielectric materials
Note: This can be used along with the MATPZO Bulk
                Data Entry for defining piezoelectric coupling.
| MAT2PT | MID | PMTVXX | PMTVYY | PMTVZZ | DAMP | ||||
| FLAG1 | FLAG2 |
| MAT2PT | 17 | 0.1 | 1.5 | 0.01 | |||||
| STRSCHG | RELATIVE |
| MID | Unique material
                                identification number. No default (Integer > 0)  |
| PMTVXX | Defines the permittivity
                                along the X direction. No default (Real > 0.0)  |
| PMTVYY | Defines the permittivity
                                along the Y direction. Default = PMTVXX (Real > 0.0)  |
| PMTVZZ | Defines the permittivity
                                along the Z direction. Default = PMTVXX (Real > 0.0)  |
| DAMP | Damping term corresponding
                                to the static electrical part. Default = 1.0 (Real ≥ 0.0 and ≤ 1.0)  |
| FLAG1 | Flag to indicate the form
                                of PMTVij coefficients.
| FLAG2 | Flag to indicate type of
                                    permittivity.
- The material identification number can be the shared with structural materials (MAT1, MAT2, MAT8, MAT9 or MGASK), thermal materials (MAT4, MAT5), or electrical materials (MAT1EC, MAT2EC) but must be unique with respect to other dielectric materials (MAT1PT).
 - MAT2PT is supported only for solid elements.
 - The electrical permittivity matrix has the following
                            form:Where,
- Vacuum permittivity
 - Relative permittivity defined by PMTVXX
 - Relative permittivity defined by PMTVYY
 - Relative permittivity defined by PMTVZZ
When FLAG=STRNCHG, the electrical permittivity matrix is expressed as:The matrix is converted to the matrix by:Where,- Elastic matrix
 - Piezoelectric coupling matrix defined in MATPZO
 - For more information, refer to Piezoelectric Analysis in the User Guide.
